Skip to content
Default applications / MIME
This article will discuss how default applications are set and ways to change them.
  1. Override default applications
  2. MIME types format
The /usr/local/share/applications/mimeapps.list & /usr/share/applications/mimeapps.list files specify which application is registered to open specific MIME types by default. These files are provided by the distribution. To override the system defaults for individual users, you need to create a ~/.config/mimeapps.list file with a list of MIME types for which you want to override the default registered application.
  1. Consult the /usr/share/applications/mimeapps.list file to determine the MIME types for which you want to change the default registered application. For example, the following sample of the mimeapps.list file specifies the default registered application for the text/html and application/xhtml+xml MIME types:
[Default Applications]
text/html=firefox.desktop
application/xhtml+xml=firefox.desktop
  • The default application (Firefox) is defined by specifying its corresponding .desktop file (firefox.desktop). The system default location for other applications’ .desktop files is /usr/share/applications/. Individual users’ .desktop files can be stored in ~/.local/share/applications/.
  1. Create the ~/.config/mimeapps.list file. In the file, specify the MIME types and their corresponding default registered applications:
text/html=myapplication1.desktop
application/xhtml+xml=myapplication2.desktop
[Added Associations]
text/html=myapplication1.desktop;
application/xhtml+xml=myapplication2.desktop;
  • This sets the default registered application for the text/html MIME type to myapplication1.desktop, and the default registered application for the application/xhtml+xml MIME type to myapplication2.desktop.
  • For these settings to function properly, ensure that both the myapplication1.desktop and myapplication2.desktop files are placed in the /usr/share/applications/ directory. Individual users’ .desktop files can be stored in ~/.local/share/applications/.
  1. You can use the gio mime command to verify that the default registered application has been set correctly:
$ gio mime text/html
Default application for “text/html”: myapplication1.desktop
Registered applications:
firefox.desktop
Recommended applications:
firefox.desktop
Consider the following example:
mimeapps.list
image/jpeg=bar.desktop;baz.desktop
video/H264=bar.desktop
[Removed Associations]
video/H264=baz.desktop
image/jpeg=ristretto.desktop
inode/directory=thunar.desktop
Each section assigns one or more desktop entries to MIME types;
  • Added Associations indicates that the applications support opening that MIME type. For example, bar.desktop and baz.desktop can open JPEG images. This might affect the application list you see when right-clicking a file in a file browser.
  • Removed Associations indicates that the applications do not support that MIME type. For example, baz.desktop cannot open H.264 video.
  • Default Applications indicates that the applications should be the default choice for opening that MIME type. For example, JPEG images should be opened with ristretto.desktop. This implicitly adds an association between the application and the MIME type. If there are multiple applications, they are tried in order.
💡 TIP: Although deprecated, several applications still read/write to ~/.local/share/applications/mimeapps.list. To simplify maintenance, simply symlink it to ~/.config/mimeapps.list:
$ ln -s ~/.config/mimeapps.list ~/.local/share/applications/mimeapps.list
Sources / Further reading:
https://wiki.archlinux.org/title/Default_applications
https://wiki.archlinux.org/title/XDG_MIME_Applications
https://help.gnome.org/admin/system-admin-guide/stable/mime-types-application-user.html.en
