How to include systemlogs in your post.
by joekamprad (taken over from Antergos and expanding it)
In the majority of cases, simply describing your issue will not provide enough information for someone to identify its cause and advise you on how to resolve it. It is important to include any system logs that may be relevant to your issue to ensure that neither your time nor the other person’s time is wasted. The following is a list of the most common system logs and where/how to obtain them. The logs are listed in order of importance.
Essential: we need to be able to reproduce the issue, so exact steps are needed.
These two outputs from your system should be included in most cases if you want help on a specific system/hardware related issue:
Hardware information:
inxi -Fxxc0z | eos-sendlog
Using the “z” option filters out most of the privacy related stuff like IP serial numbers e.t.c :
-z, –filter Adds security filters for IP/MAC addresses, serial numbers,
location (-w), user home directory name, host name. Default on
for IRC clients.
Boot log:
See journalctl for options.
journalctl -k -b -0 | eos-sendlog
Run the commands and share the short-url in your post.
It will show like so in your terminal:
terminal output of pastebin tool
Partition and format info:
lsblk -o name,type,size,PTTYPE,FSTYPE
Provide Installer Logs (calamares ISO LiveSession):
Section titled “Provide Installer Logs (calamares ISO LiveSession):”While you are still on the ISO Live Session logs are stored inside livusers home:
/home/liveuser/endeavour-install.log
You can open with text editor or from file browser, or send via tools (needs internet connection):
cat ~/endeavour-install.log | eos-sendlog
You can simply share the short URL it produces inside a terminal.
On an installed system, the log from the installation process is stored under:
/var/log/endeavour-install.log you can also send it but needs admin to read:
sudo cat /var/log/endeavour-install.log | eos-sendlog
In addition, you can use the log GUI tool from EndeavourOS:
A general warning about logs:
Section titled “A general warning about logs:”If sending/posting system journal, please keep in mind that it could include personal data!!
So consider using something like
journalctl -b -0 | grep fail | eos-sendlog
So it will only show the lines including the search term “fail” per example.
Or send the log in a P.M to a user you trust in that matter, so your log will not be visible in public.
Info on different logs and tools you can use to fetch and share system information:
Section titled “Info on different logs and tools you can use to fetch and share system information:”Systemd Journal:
Section titled “Systemd Journal:”The systemd journal can only be accessed using the journalctl command.
journalctl -b -0 # System journal, most recent
journalctl -b -1 # System journal, 2nd most recent
journalctl -b -2 # System journal, 3rd most recent
The most interesting one is the last boot in most cases.
Learn more about the Pastebin command further down.
Note that EndeavourOS has a simpler way to Pastebin. For example:
cat file | eos-sendlog
The program eos-sendlog will (by default) save the received URLs to ~/.config/eos-sendlog.txt for later inspection.
Xsession:
Section titled “Xsession:”Your session log is located in your /home directory:
~/.xsession-errors
~/.xsession-errors.old
Xorg (X11):
Section titled “Xorg (X11):”You can find your Xorg logs here:
/var/log/Xorg.0.log
/var/log/Xorg.0.log.old
Lightdm:
Section titled “Lightdm:”LightDM’s logs can be found here:
/var/log/lightdm/lightdm.log
/var/log/lightdm/x-0-greeter.log
Other log providers and options:
Section titled “Other log providers and options:”journalctl --since "10 minutes ago"
To get the journal from a given timespan (works also with hours seconds, days)
A good way to get information about a particular program:
journalctl -f /usr/bin/"Executable"
Journal from an exact timespan:
journalctl --since "2025-11-08 10:00:00" --until "2025-11-08 11:00:00"
also:
journalctl --since "2 hours ago" --until "30 minutes ago"
and yes:
journalctl --since "2025-11-08 10:00"
You do not need to add hours/minutes too:
journalctl --since "2025-11-08 10" --until "11:30"
And nice to post a Pastebin the smart way:
"command" | curl -F ‘file=@-’ 0x0.st
or using EndeavourOS tools:
"command" | eos-sendlog
System summary and boot log example:
lspci > log.txt && lsusb >> log.txt && journalctl -b -0 >> log.txt && cat log.txt | curl -F ‘file=@-’ 0x0.st
Or use eos-sendlog:
lspci > log.txt && lsusb >> log.txt && journalctl -b -0 >> log.txt && cat log.txt | eos-sendlog
The program eos-log-tool is a GUI for various logs and system files.
Other systemd logs/analyze:
Section titled “Other systemd logs/analyze:”systemd-analyze blame
will show times of systemd stuff needed to proceed on boot up
https://www.freedesktop.org/software/systemd/man/systemd-analyze.html
Pastebinit:
Section titled “Pastebinit:”install pastebinit with package manager or sudo pacman -S pastebinit
the command should be passed like this:
journalctl -b -0 > ~/journal.txt && pastebinit -i ~/journal.txt -b lpaste.net
Where you can change journalctl -b -0 with any other command like dmesg from below, his will write to a text file: ~/journal.txt under your home you can change this name (journal) to something related to the command you pass.
pastebinit will auto-upload this to the Pastebin service you can choose (list all available by pastebinit -l
then it gives the link to it as output, so that you can just copy t to paste inside a post.
System summary and boot-journal example:
lspci > log.txt && lsusb >> log.txt && journalctl -b -0 >> log.txt && pastebinit -i log.txt -b lpaste.net
This will give out a link (like this:http://lpaste.net/7802695579456241664) you can post onto the forum, this will include all the output of:
lspci (list your pci devices) lsusb (same for USB) and dmesg (boot up messages) and make it available.
The dmesg command:
Section titled “The dmesg command:”An alternative to the above command (or if your system is not using systemd) is the good old dmesg command. This is potentially less informative than journalctl above, but not if you have filtered it as I advised you to. So they are essentially equivalent.
sudo dmesg
Again, If you look in its man page or type invoke dmesg --help you’ll learn about the always useful -l flag, which filters dmesg potentially long output to print only certain message levels. And the -r flag which prints the message level. So, likewise, many of us will thank you if you do the following instead of the above:
sudo dmesg -rl warn,err,crit
Or at the very least:
sudo dmesg -r
Trivia: The dmesg command is basically the same as journalctl with the -k flag added to it
Hardware Information Systems:
Section titled “Hardware Information Systems:”INXI: smxi.org
inxi -Fxxc0z
all inxi options in detail:
https://smxi.org/docs/inxi-options.htm
Or to auto-pastebin it and get a URL to post:
inxi -Fxxc0z | curl -F 'f:1=<-' ix.io
using the “z” option filters out most of the privacy related stuff like IP serial numbers e.t.c : -z, --filter Adds security filters for IP/MAC addresses, serial numbers, location (-w), user home directory name, host name. Default on for IRC clients.
So also if you use inxi for showing only parts of the info like inxi -Aa to show audio hardware details you should always add -z to the used command if you want to share the output:
inxi -Aaz
EndeavourOS log tool
Section titled “EndeavourOS log tool”We also have a GUI app to handle logs which will come in handy if you are not that firm on using all the commands from terminal:
After selecting the logs you want to share, it will create the log and Pastebin this for you so that you easily can share this URL on the Forum or in the Help chat:
ℹ Final Note:
Section titled “ℹ Final Note:”Very important! Do not paste only the printed contents of the command.
Always show also the command you used to get that output.
And better to use an external Pastebin if the output is very large because it is hard to get the overall question visible, inside your post, or for the discussion, if it is interrupted by large logs!
At the Forum, you can use also the summary option to hide the text/log itself and instead show an arrow to open it:
