Mirrors intro
What are mirrors and why are they important?
Section titled “What are mirrors and why are they important?”Mirrors are the package servers we use when installing or updating packages. There are lots of mirrors (for Arch) around the world, and to keep package updates running smoothly, the mirrors should be both:
- fast (high data rate and responsiveness)
- up to date
On an EndeavourOS system, Arch mirror addresses are gathered as a list into file /etc/pacman.d/mirrorlist.
In the /etc/pacman.d/mirrorlist file, lines that begin with a # are ignored, and then the order (from top to bottom) is respected. If a problem exists with the first entry, pacman defaults to using the next active line down.
Usually (but not always) the closest mirrors are the fastest. That’s why we usually want to use mirrors from the user’s current location (country) or some nearby countries.
Another important factor is that the mirrors we use are up to date, meaning they have been synced with the master Arch package server recently. Better to use a mirror that has the latest Arch packages.
Yet another (temporary) concern may be that a particular mirror is offline, e.g. under maintenance. Sometimes a mirror may even be permanently offline.
That’s why having a decent list of mirrors on your machine is important.
Note that the list of mirrors can (and usually should) be ranked to get the best experience when updating or installing packages. Ranking mirrors organizes the list of mirrors so that the best mirrors for your location are at the beginning of the list.
Mirror ranking tools
Section titled “Mirror ranking tools”EndeavourOS has the following tools directly available for ranking the Arch mirrors (in alphabetic order):
- rate-mirrors
- reflector
- reflector-simple
Each of them has pros and cons, so experimenting in your location may be needed to have a good result.
What about EndeavourOS mirrors?
Section titled “What about EndeavourOS mirrors?”EndeavourOS has its own packages as well, thus EndeavourOS has its own list of mirrors and you can find the mirror list is in file /etc/pacman.d/endeavouros-mirrorlist.
To be able to rank EndeavourOS mirrors, first you need to install eos-rankmirrors package if not already installed.
yay -S --needed eos-rankmirrors
EndeavourOS mirrors can now be ranked with a terminal command (note: call without sudo!)
eos-rankmirrors
It fetches the latest EndeavourOS mirrorlist from the EndeavourOS development site, and ranks the mirrors found in that list. Then it shows you the ranking result, and prepares to write the ranked list to file /etc/pacman.d/endeavouros-mirrorlist. For writing the file it needs elevated privileges, and asks you the required password.
Note that eos-rankmirrors can be configured with file /etc/eos-rankmirrors.conf. For example, to make the ranking process significantly faster, you can exclude mirrors you know are very slow or not always working well. Use variable EOS_IGNORED_MIRRORS for that by adding unique partial names of mirrors to the variable (using bash syntax).
Alternatively, rate-mirrors can rank EndeavourOS mirrors as well.
