Skip to content
Removing a Desktop Environment
If you have changed to another DE (Desktop Environment) after initially installing the offline edition (XFCE4) or you just decided to move over to your freshly discovered DE, you might want to remove the unused one.
In most cases, this isn’t easy to do, especially when you switch from GTK to QT, or vice-versa, there are still some dependencies you might need.
So I try to give an example here, the best practice is to update your system first:
sudo pacman -Syu
Use desktop installer helper script eos-packageslist:
Section titled “Use desktop installer helper script eos-packageslist:”
We have little helper script for handling DE/WM installs eos-packageslist that makes the handling more convenient for you:
example:
eos-packagelist --install "GNOME-Desktop"
more options on the tool: eos-packagelist --help
To list available groups eos-packagelist --list
A trick to uninstall per example a fresh offline XFCE4 after you installed an alternative Desktop:
create packages list for default xfce4:
eos-packagelist "XFCE4-Desktop" > xfce4
remove packages from that list:
sudo pacman -Rc - < xfce4
But check exactly what will get removed here too dependencies can be a hell ;)
login to TTY4:
give username and password to login as user.
now follow these steps:
  1. uninstall old Desktop: eos-packagelist "XFCE4-Desktop" > xfce followed by: sudo pacman -Rc - < xfce4
  2. install new Desktop: eos-packagelist --install "GNOME-Desktop"
  3. Make sure base system is intact: eos-packagelist --install "Desktop-Base + Common packages"
  4. change Display Manager: sudo systemctl -f enable GDM
You can do this also while logged in to your current Desktop, but uninstalling it while using it can cause freezing.
Unfortunately, there isn’t a full-proof way to do this, so always take a look at the exact terminal output, and be careful you do not uninstall certain system relevant packages or packages you have installed manually like a preferred browser or other apps.
If you remove an DE make sure to enable the new DM (LoginManager) before rebooting the system or you will boot into TTY without graphical login like this:
In that case, you will need to enable the DM manually:
sudo systemctl -f enable --now GDM
To get the graphical Login-Manager show up again.
This is only one example of the situation you could run into, but most of the time these steps will be enough for any DE change.
In case you are encountering issues, don’t forget to ask our helpful community.
You can find the lists also in this GitHub Repo:
Section titled “You can find the lists also in this GitHub Repo:”
reinstall DE commands at GitHub
So choose your new DE and copy and paste the command in your Terminal:
In this example I use GNOME:
git clone https://github.com/endeavouros-team/EndeavourOS-packages-lists.git
cd EndeavourOS-packages-lists
ls will list the files
sudo pacman -S --needed - < gnome
will install Gnome packages.
