Skip to content
Set-up Periodic TRIM
[Source: Periodic_TRIM]
Warning: Users need to be certain that their SSD supports TRIM before attempting to use it. Data loss can occur otherwise!
check if your drive support it:
Terminal window
sudo hdparm -I /dev/sdx | grep TRIM
(change to the drive letter (x) you want to check)
make sure util-linux is installed:
Terminal window
sudo pacman -S util-linux hdparm --needed
check what you have already running:
cat /etc/fstab
if your drive shows like this:
/dev/sda1 / ext4 defaults,discard 0 1
continous TRIM is enabled! what in my opinion is bad to use as it will put system under continous load…
enable periodic TRIM:
remove discard option from your device inside fstab that it looks like this:
/dev/sda1 / ext4 defaults 0 1
Starting the scheduler to trim device/s once a week::
Terminal window
sudo systemctl start fstrim.timer
sudo systemctl enable fstrim.timer
to check if it works see:
Terminal window
systemctl status fstrim.timer
